1997 Dodge Caravan Both Front Brakes Dragging on rotors
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
GSTANZIO
What is causing brake pads to drag on front rotors? Changed out calipers and pads, and still they are dragging. Would this be ABS related or hydraulic manifold? Thanks,
Apr 14, 2008 at 8:03 AM
MERLIN2021
  • 17,250 POSTS
When the drag happens jack up one side and loosen the bleeder, does it spin free now? If yes chang the flex hose, if no, check rear brakes and master cylinder and fluid for signs of contamination...such as some one putting tranny or power steering fluid in the master...if it has a ride hieght sensing valve in the rear, it may need to be adjusted, you need a pressure gauge to do that!
Feb 21, 2021 at 5:16 AM
