Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Electrical
Battery
Location
1997 Dodge Caravan Battery Temp Sensor?
1997 DODGE CARAVAN
245,000 MILES • 6 CYL • AWD • AUTOMATIC
BRIANDOWNS
MEMBER
1 POST
I am getting code 1492. I can't seem to be able to locate the cause - new battery, wiring, etc. Where is the actual sensor? Can it be replaced?
Oct 12, 2010 at 3:57 AM
BLUELIGHTNIN6
Experienced Mechanic
The battery temp. sensor is an internal part of the powertrain control module, your PCM will need replaced.
Oct 12, 2010 at 4:13 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
