I have changed the crank timing sensor, but the problem still remains, i have tried adjusting the sensor many, many times, but no better results, it seems to happen when encountering a slight grade while speeding up or when calling for more speed to pass, it seems to be worse when engine is hot, on hot days and while a/c is on
I recently replaced the fuel pump, and have checked for vacuum leaks and replaced bad sections, have changed air filter, pvc etc, also had the tranny shift module changed
Any advice will be helpful
Thank you in advance
Jul 24, 2009 at 3:47 PM
