Took the van in for repair of the front axles. The seals were totally missing, grease was gone, and bearings exposed. When I picked up the van, the ABS light came on. I took it back and they said the "ABS sensor had gone bad." Since the sensor "went bad" at the same time of the repair, I suspected the shop broke something during the repair and asked them. They denied any connection between the two. After a bit of research on line, I'm wondering whether they may have installed the wrong axles (a non-ABS axle instead of one with ABS). Does that make sense? The invoice I received has no part numbers, so I can't compare. Is there anything visual I can check (without removing the part?) Thanks,
Dec 23, 2007 at 5:15 AM
