1997 Dodge Caravan 1997 Dodge Grand Caravan heater
NLARVIE0964
Heater problem
1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic
I have a 1997 Dodge Grand Caravan. The heater panel has a driver and passenger setting for the heat to be cool or hot. The driver side is set to hot and works great while the passenger side is also set to hot but blows cool air out. Why does the driver side blow hot air and the passenger side blow cool air? Also how do you get the passenger side rear window to open? Where is the motor for this?
Mar 19, 2010 at 7:09 PM
BMRFIXIT
  • 19,053 POSTS
suspect blend door run a code check Heater system is a blend air type. Outside air enters heater system through cowl grille and passes through plenum chamber to heater unit. Blend-air door, located inside heater unit, routes incoming air through or past heater core. Amount of blended air is controlled by temperature control lever. Air distribution is controlled by mode selection and blower speed.
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_686.jpg
Removal & Installation (Left Side) Remove rear header trim cover. Remove liftgate sill plate. On long wheelbase models, remove second rear seat belt turning loop. On short wheelbase models, remove bolt securing second rear seat belt lower anchor to quarter panel. On all models, remove jack storage cover. Remove "D" panel retaining screws. Using a trim stick, gently pry around perimeter of "D" pillar trim panel and separate trim panel from inner quarter panel. Disconnect rear speaker connector (if equipped). On short wheelbase models, pass seat belt through slot in "D" pillar. On all models, remove "D" pillar trim panel. To install, reverse removal procedure. Removal & Installation (Right Side) Remove rear header trim cover. Remove liftgate sill plate. On long wheelbase models, remove second rear seat belt turning loop. On short wheelbase models, remove bolt securing second rear seat belt lower anchor to quarter panel. Remove quarter panel trim bolster. On all models, remove "D" panel retaining screws. Disengage hidden "D" pillar trim panel clips. Separate "D" pillar trim panel from "D" pillar. Disconnect rear speaker connector (if equipped). Remove trim panel. To install, reverse removal procedure. Disconnect power vent motor connector. Remove nut securing crank to vent glass. Remove bolts securing power vent motor to "D" pillar. Remove power vent motor. To install, reverse removal procedure.
Mar 19, 2010 at 8:30 PM
