1997 Dodge Caravan
JERRYTJ
  • 1997 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 184,000 MILES
My van want turn over to start. I put new coil pack new cam shaft position sensor new crank shaft sensor and new fuel pump and none of that has helped the matter. Can you please help with this matter?
Monday, February 23rd, 2009 AT 5:37 PM
BMRFIXIT
  • 19,053 POSTS
Check ASD relay
check fuses
check for code s cycle key on off on off on
read codes in odometer area
what engine do you have?
If with timing belt check timing and timing belt
what is it you do not have (spark, fuel, injector pulse )
let me know
Monday, February 23rd, 2009 AT 5:42 PM
