1996 T&C & 2000 caravan headlamp lenses
CAMA81Z
Hello , I own a 1996 Town & country & a 2000 Grand caravan . Both of the lenses on both cars are extremely cloudy it block the lighting power at night .
I have tried an abrasive cleaner pad the is supposed to work but it didnt .
Do you have any suggestions , or do I just need to replace them ?
thanks
ed
May 28, 2007 at 4:49 PM
E40WATER12
  • 522 POSTS
Ive got 89 dodge shadow that had the same problem, I pulled the headlight units out, I found the seams around the headlight units are cracked,Once the got to silicone sealer on them, No moister has gotten in, They work great now, Also I bought a set of after market foglights, for night time driving as well. If that re-sealing trick doesnt work, I would get used ones from the wrecking yard.
Good Luck
Jun 2, 2007 at 1:17 PM
