1996 Dodge Caravan WON'T START
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
USACATS
WAS DRIVING MY VAN...THEN IT JUST SHUT DOWN. IT WOULDN'T RESTART UP. HAS POWER, TURNS OVER BUT DOESN'T RUN. HELP
Jan 18, 2008 at 11:11 AM
BLACKOP555
  • 10,386 POSTS
First i would like you to check for fuel pressure, or you can choose to spray starting fluid in the throttle body while cranking it, if it fires up then you not getting fuel, if not then chances are you have no spark and you should check that next, post back what you find if you need further help.
Jan 18, 2008 at 12:46 PM
