1996 Dodge Caravan wont start
214,000 MILES • 6 CYL • FWD • AUTOMATIC
MARIONH
  • 20 POSTS
While I was driving, my van quit and has not started since. Ive got compression, fuel, and spark to 4 cylinders. It will crank, (not start) but only when the battery gets to a low voltage. Ive changed the cam and crank sensors and coil pack twice.
I was thinking on changing the ecm, but before I do spend that money was wanting to see if you had any other ideas and if in my ecm is there different ports or whatever they are called that operate different cylinders? Im not getting spark to the 2 and 5, but all the rest spark intermittently
Jun 4, 2010 at 12:36 AM
  • 110,251 POSTS
It could be the ignition control module. It is located under the hood, center, rear engine area. It's mounted in distributor.
Jun 4, 2010 at 4:47 AM
MARIONH
  • 20 POSTS
My vehicle dont have a icm or a distributer. Its all run from the ecm.
Any other thoughts?
Thanks
Jun 4, 2010 at 7:18 AM
  • 110,251 POSTS
Interesting... WHat size V6 do you have. I remember looking this one up and found that it does have and ICM, but it may have been for a different V6. Let me know.
Jun 5, 2010 at 11:14 AM
MARIONH
  • 20 POSTS
Ok, now that ive replaced the ecm, Ive got fire and she wants to start, however im not getting fuel into the intake. I had a man come over with a diagnostic machine and he said the engine is telling the ecm that its 180 degrees. My oil pressure is between 45 and 47 and I have correct timing.I noticed last night when I try to start it that the headlights try to come on. Im confused for sure now.
My van ihas been modified for a wheelchair, It also has what I thought was just a panic button, but Im guessing its an alarm system, but it has nover done more that set off a horn of some type when I hit the panic button on the key chain.
Im wondering if I got a defective ecm or if you have anymore suggestions.
God bless you for all you do
Jun 8, 2010 at 12:17 AM
  • 110,251 POSTS
Replace the temp sensor. It is designed to tell the computer what the ambient and coolant temp is so the computer knows how rich or lean to make the fuel mixture.
After thought... Before replacing it, see if it will start with starting fluid. Let me know what you find.
Jun 8, 2010 at 6:47 AM
MARIONH
  • 20 POSTS
I didnt have starting fluid, but sprayed gas directly into intake, and as long as I could get gas in there it would run for a few seconds, but as soon as the gas burnt off it died again.
I guess Im gonna try the temp sensor. Ill get back to you soon.
Thanks again
Marion
P.S. Was wondering if my gas was bad, as I got real low on fuel so I put $10 in the tank,, I mean almost empty, then went about 5 miles, and thats when it died.
Jun 8, 2010 at 7:09 AM
  • 110,251 POSTS
You have a fuel pump issue at this point. Check the fuel pump pressure both before and after the fuel filter. The filter may be plugged from running it that low or it may have damaged the pump.
Let me know what you find. If you need directions, let me know.
Jun 8, 2010 at 7:18 AM
MARIONH
  • 20 POSTS
Let me start by saying you are a god send!!
I have checked the fuel pressure at the fuel rail, it reads 45-47, as far as checking it before the filter, Im lost!!
I also noticed that when I try to start it without stepping on the throttle is when it tries to start, however, if I try to put any throttle to it, nothing happens.
I went to the parts house and got a bottle of "heet" to try to dry up any water if any was in there, still nothing.
Please help me, Im desperate!!
Thanks a million
Marion
P.S. Is there an access panel inside of the van to get to the fuel filter, and is there more than 1 filter?
Jun 8, 2010 at 1:21 PM
  • 110,251 POSTS
First, I'm glad to help. I enjoy helping good people. I double checked the fuel pressure requirements. I found it should be at 49psi, but 47 should run the vehicle. If it is running when you put fuel to it manually, now I have to question the injectors. If you have fuel pressure at the fuel rail, the last step is to inject it into the engine. I hate to say it, but we need to do one more test. You will need a simple light called a "noid light." Most parts stores will lend or rent it to you. What you do with it is simple. You disconnect one injector at a time, plug the power side wiring that was going to the injector into the light. When you crank the engine, the light should pulse on and off each time the injector should fire.
I hate to keep asking you to check things. If it was in a shop, these things could be done very quickly. I realize it is a pain. Also, now that you are getting spark, is it a blue snapping hot spark or more orange or white?
Jun 8, 2010 at 2:13 PM
  • 110,251 POSTS
Sorry, I forgot to tell you where the fuel filter is. It is under vehicle on the passenger side, below seating area, front of fuel tank, mounted on frame in fuel line. It is accessed from under the vehicle.
I knew I forgot something when I hit send.
Jun 8, 2010 at 2:16 PM
MARIONH
  • 20 POSTS
I think I remember the guys that were helping me doing the test on the injectors and the light was a pulsing blue light. I was thinking there was a 2nd filter but didnt exactly know where to look as the van was modified for a wheelchair. The floor has been dropped 10 inches all the way to the back seat to modify for the wheelchair and the gas tank is now all the way in the back of the van where the spare tire used to be.
Ill get back to you after I find the filter.
This mechanic stuff is definitely for men, being a woman, I've broke all my nails, and how do you get the funk off of your hands? lol
Jun 9, 2010 at 2:50 AM
MARIONH
  • 20 POSTS
Gonna double check with the guy helping me, what does it mean if the light was orange or whatever color you said?
Bty, I looked at your profile and noticed your from PA. Im originally form Bradford Pa. been in Al for 14 years
Marion
Jun 9, 2010 at 3:21 AM
  • 110,251 POSTS
Take a scrub brush and scrub under the broken nails. That is about the only way to clean them. I'm outside of Pittsburgh, but after this winter, ready to move south.
As far as the colors you asked about, I was refering to the color spark the plugs were getting. It should be blue in color. If it is white or orange, it is weak.
Jun 9, 2010 at 5:54 AM
MARIONH
  • 20 POSTS
ok, so I tried everything you said, all checks out. I replaced the ecm again, thinking it was faulty and still the same thing.
Could it be the ignition switch or what? Im so frustrated!!
What else can I do?
Pleeeeasssse help
Marion
Jun 12, 2010 at 2:51 AM
MARIONH
  • 20 POSTS
btw, could it be the map sensor
Jun 12, 2010 at 2:52 AM
MARIONH
  • 20 POSTS
After weeks of research, I was wondering if you can tell me according to your expertise what the fuel pressure should be at the fuel rail.
Also, do i have an ignition control module, where it , would be and could you send me a diagram of it, and if this would cause my issues. what bout a iac? Im at my wits end!!!!!!!
Jun 12, 2010 at 3:58 AM
MARIONH
  • 20 POSTS
After reading through the forum, I found a guy with a similar problem, ended up it was his map sensor. I went and disconnected mine and kinda wanted to start, but not really. I did the code search with the check engine light and didnt detect it was even unplugged, starting to think this is my problem because it says it will act like a bad fuel pump. What is your opinion and shouldnt that map being unplugged set a code?
Thanks
marion, , below is his post
Posted at Fri Jan 15, 2010 1:08 am
By bluehapp, New 2Carpros Member
(6) Give Feedback | Votes: 0
I went to pull a part and got a eng control module for 12 bucks.
Went home trying to figure the compatablity from 1988 to my 1989, I ran across the MAP sensor test. The author said the MAP sensor will act like a failing fuel pump. The car will try to start but will die like the fuel pump is bad. The test is simply to unplug it. The car will run ruff but not die after starting. I did this and went to pull a part and got two for 3 dollars. Problem solved. When I unplugged the dang thing I got a code 14. If I would have known the MAP sensor acts like this I could have saved a lota time. Thanks for your input anyway... John.
Jun 13, 2010 at 4:36 AM
  • 110,251 POSTS
Yes, a map sensor could cause the engine to die and seem like it's not getting fuel. Also, you asked what the fuel pressure should be, the book says 49PPSI at the rail. Even though you are not getting a code for a map sensor, it may not be a bad thing to try.
Jun 14, 2010 at 4:45 AM
MARIONH
  • 20 POSTS
ok, so here is my latest,,, actually got it running last night, runs beautifully!!!! The crank sensor had to be readjusted. Fabulous, its back on the road, or so I thought.
Started it up today, had a fuel leak in the filler neck of the tank. Went to a shop and got it changed out,, ran great for about 50 miles. then it happened again, it started, but was rough, and would only go bout 5 mph, smelled real funny( like funny gas,, maybe,, don't really know how to explain the smell), so I waited 2 1/2 hours for a tow truck after we got if off the flat bed, it started like nothing was wrong, but it set a code 11 on the dtc. which means no crank to the ecm. Am I missing something?? Maybe something that makes it act up when hot,, idk, was still wondering bout the map sensor, and if would act like that if it was the map sensor or would it throw a map code?
Please help
Thanks
Marion
Btw, I was talking to a guy at the junkyard, he said there is some sort of box under the dash, drivers side, bout 3 by 3 that the security system goes through that might be causing this issue im having. He couldn't remember the name of the part, but if you could tell me I'de try it.
Jun 14, 2010 at 2:00 PM
MARIONH
  • 20 POSTS
hope all is well with you, havent heard from you since my last post.
Is it possible that I got a bad crank sensor in the beginning? On these vans, do the parts actually have to be mopar, or can they be aftremarket?
Jun 16, 2010 at 3:33 AM
  • 110,251 POSTS
Sorry it took so long to get back. I was out of town for a few days.
As far as your question, an aftermarket should work fine; however, I have gotten bad ones. As far as the map sensor, that could be the problem. Have you checked it? Also, make sure the crank sensor didn't move on you again.
Jun 16, 2010 at 2:32 PM
MARIONH
  • 20 POSTS
So, how exactly do you check the map sensor? Why would the crank sensor go out of wack again, is there some kind of vibration that would cause it, and is it normal to work right when cooled off?
Btw, I just found out when my son-in-law put the crank sensor in, he didnt use that little spacer paper, is there anything else I can use in place of it?
Jun 17, 2010 at 2:18 AM
  • 110,251 POSTS
That could be the entire problem. It needs to have a specific gap. Do you think the parts store would allow you to remove one from a new sensor and then returne it?
Jun 18, 2010 at 8:31 AM
MARIONH
  • 20 POSTS
ok, so i had the sensor corrected, and drove 65 miles and it started putting on me again, the code read 51,,, what does this mean?
Jun 21, 2010 at 6:40 AM
  • 110,251 POSTS
51 = Oxygen sensor output indicates lean too long. This could be something as simple as a vacuum leak, bad sensor, bad wiring to the sensor, or low fuel rail pressure from a weak or bad fuel pump.
This is what it takes for the code to be set. Sensor output indicates lean for more than 715 seconds (11 minutes, 55 seconds)
Results If Component Fails
A fault code 51 is stored, the circuit stays in closed-loop, and the logic module will still monitor the oxygen sensor signal. If the condition persists for four times what it took to set the code, the logic module will allow the engine to run rich, but prevent it from running lean. I would recommend checking fuel pump pressure under when it happens and if it is good, then check the sensor and wiring to the sensor. A rich mixture will cause it to run the way you described.
Jun 21, 2010 at 3:51 PM
MARIONH
  • 20 POSTS
I found that there was a cover off a small vaccuum, that goes from something into the intake manifold, I actually knew this was missing after I fixed the crank sensor. I went to the part store and got a cover, replaced it, and now Ive had the van running for about 25 minutes. If I just let it sit and idle for hours, will the same thing occur if that wa s the problem or does it actually need to be driven? Its been 100 degrees out and I dont want to get stuck out in bfe again.
Whta sensor are you talking about, the o2 sensor, and if so, where is it located?
Another thing, when I started it up, there was a slightly unusual humming coming from the back of the van,, I think it was coming from the back,, what could that be?
Its been running in the driveway for 2 hours and nothing happened. I finally shut it off. Hopefully this was the problem,, what do you think????
I appreciate you so much!!
Jun 22, 2010 at 1:29 AM
  • 110,251 POSTS
First, I'm really glad to help, so you are welcome. I enjoy trying to help good people, and you seem like one.
As far as the problem, it sounds like you may have fixed it. My only concern is the noise you heard from the rear of the vehicle. That could have been the fuel pump. Is there any way to drive it a long distance in a safe area incase it dies on you?
By the way, we must be near the same age. I haven't heard BFE for a long time. (lol)
Jun 22, 2010 at 12:16 PM
MARIONH
  • 20 POSTS
Im gonna drive it today, as far as the humming in the rear end, it may have just been the fuel pumps normal sound, but I might have looked more into it because ive been trying so hard to get it running.
As far as bfe,,, Im originally from Bradford, my brother used to live in West Mifflin. But I usually dont tell my age but,,,, Im 45
LOL
Ill get back to you this afternoon after I drive it.. wish me luck
lookoing froward to your reply
Marion
Jun 22, 2010 at 11:33 PM
MARIONH
  • 20 POSTS
ok, its me again.
I drove it today 65 miles b4 it started spitting. I stopped for about 15 min and started going again. No codes were set.
Now what????
Where is that o2 sensor located?
Jun 23, 2010 at 6:56 AM
  • 110,251 POSTS
I knew it! I'm about 35 miles east of Pittsburgh and the same age. (LOL) Where on god's earth are you now?
As far as the O2 sensor, it is on the exhaust system between the engine and the converter. Before checking that, there are other things that could cause a lean mixture, vacuum leak, weak fuel pump... Since you heard the noise from the rear, I'm questioning the fuel pump. Here is a "how to" for checking pump pressure. Check it and let me know what you find. The how to will provide directions and it also contains a video to show you how to do it.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Jun 23, 2010 at 4:52 PM
MARIONH
  • 20 POSTS
Good morning,, Im now located in North Alabama. Small town just north of Huntsville, in Hazel Green,,aka- bfe (lol)
Got to checking the van last night, I think the noise I heard was coming from the exhaust,, now that I think of it, it was sounding funny b4 it broke down a month ago, I checked last night and theres not much air coming from the tailpipe, but what does come out is putting out of there. How possible is it that my converter is plugged? Btw, I remembered, while driving, about 10 miles b4 it starts acting up, it has a smell of rotten eggs,, maybe sulfer for a few minutes and its when Im going up a slight hill, then it goes away and like I said, a few miles later is when it starts chocking itself out. When I got off the road, I sat for 10-15 minutes, but while I was sitting, I kept trying to give it gas and it was chocking itself if that makes sense. In a few minutes, it worked fine and I drove home
Thnaks again for everything2!!
Jun 23, 2010 at 11:36 PM
MARIONH
  • 20 POSTS
I went to the part store and got some seafoam. Put it in it blew smoke all over the engine, not much out the exhaust, so I determined the converter is plugged, Whats your thoughts?
Marion
Jun 24, 2010 at 7:32 AM
  • 110,251 POSTS
That is very possible. When the engine is hot and has been run for some time, check to see if the converter is glowing red hot. If it is, replace it. You could also disconnect it to see if it improves the performance.
Jun 24, 2010 at 5:48 PM
