1996 Dodge Caravan WON'T START
USACATS
  • 1996 DODGE CARAVAN
  • 6 CYL
  • 175,000 MILES
WAS DRIVING MY VAN. THEN IT JUST SHUT DOWN. IT WOULDN'T RESTART UP. HAS POWER, TURNS OVER BUT DOESN'T RUN. HELP
Friday, January 18th, 2008 AT 7:11 PM
BLACKOP555
  • 10,371 POSTS
First I would like you to check for fuel pressure, or you can choose to spray starting fluid in the throttle body while cranking it, if it fires up then you not getting fuel, if not then chances are you have no spark and you should check that next, post back what you find if you need further help.
Friday, January 18th, 2008 AT 8:46 PM
