Electrical problem
1996 Dodge Caravan Two Wheel Drive Automatic 95000 miles
Recently replaced wiper motor with a new one from Advance Auto Parts. Wipers have worked fine till today (6/12/2010)....turned wipers on and initially they both moved very slowly then stopped in mid- windscreen position. Would not work in either the "intermittant" detents or the slow position; however they seem to work fine in the hi-speed position.....except they will not go to the full down position unless the switch is turned to "off" at the exact bottom of the sweep (in other words - wipers stop wherever the switch is positioned to "off").
Jun 12, 2010 at 12:45 PM
