1996 Dodge Caravan windshield wiper
AL1308
Electrical problem
1996 Dodge Caravan 6 cyl Two Wheel Drive Automatic
Having intermittent problem with my windshield wipers. I have replaced the switch on the steering column. The wipers fail to operate. Sometimes they work..then stop..sometimes they wouldn't even try to run.... seems to be to be an electrical connection??? or misconnection...loose ground??? where????
When they are in the "failed mode" I can use the "washer" to cause the wipers to operate once...then they will stop again. If I leave it in any of the "intermittent" speed postions..it may start working albeit at a "different speed"...I have had times when I put it in the normal slow speed run and they will operate very slowly then stop.
How do I get to the wiper motor mount???
thanks al
Oct 15, 2009 at 1:31 PM
BMRFIXIT
  • 19,053 POSTS
start by checking the relays
RELAY IDENTIFICATION (UNDERHOOD)
B - Front Wiper Hi/Lo Relay
C - Front Wiper Relay
Oct 15, 2009 at 11:10 PM
