1996 Dodge Caravan will not start!
BWTA
1996 Dodge Caravan 6 cyl Front Wheel Drive Automatic 160ish miles
i just finished doing the head gaskets on the van . the timing is right [i think] ,there is spark and gas but it does not start. when i try to start it, it sounds like it wants to start but it won't. i checked the ignition codes, and code 25 comes up. i don't know what to do now! any suggestions greatly appreciated!
Aug 19, 2010 at 3:52 AM
  • 110,251 POSTS
Here is a description of a code 25 that I was able to get for you.
Description: AIS (Automatic Idle Speed) motor circuit shorted or target idle speed not reached
Power loss light: Off
Limp-in mode: None
Possible Causes
Vaccum leak - Check all vaccum lines for cracks or breaks.
Bad connection or wiring - Check the wiring and connections between the logic module and the motor. Clean and regrease any corroded connectors with dielectric grease and repair any shorts.
Shorted or frozen AIS motor - The AIS motor is located near the TPS. For 1987 or earlier Turbo I engines, remove the bolt and slide the motor out (you may have to wiggle and twist it). Remove the clamp and carefully pull out the motor. Be sure and observe how it goes together, especially the orienation of the rotatiing valve inside. Hook the motor to a 12V supply to see if it runs. If it doesn't, replace the AIS. Clean all the gears and shafts throughly and reassemble the gear and valve assembly. Spray all the gears and parts with TriFlo or a similar silicone spray lubricant (don't use WD40 because it evaporates) and insert the motor. If the engine seems to race wildly after assembly (give it some time to get control), you probably installed the internal, rotating valve backwards.
Are you sure all vacuum hoses are replaced?
Aug 19, 2010 at 3:23 PM
