1996 Dodge Caravan Turn Signals
PAUL5253
Electrical problem
1996 Dodge Caravan 6 cyl Front Wheel Drive Automatic
I have installed turn signals on each side mirror (LED type). I now need to wire them to the vehicle. What is the best/shortest route to the vehicle turn signal wiring?
Dec 1, 2009 at 3:49 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Run both wires behind the mirror and through the door jam, Under your dash to your fuse box. Connect the positive wire to your turn signal flasher fuse. Ground the negative wire off to any strong ground. Once they are connected when you put your turning signal on it should flash on your side mirrors which ever way you are turning. If not check your ground connection and ensure you inserted positive wire to correct fuse.
Dec 1, 2009 at 5:18 PM
