1996 Dodge Caravan Transmission is not working properly in
EUROAIT
  • 1996 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 170,000 MILES
After shifting in 1, 2 or D my car is not moving forward, engine is getting more accelerated with max. Rpms. But car stays on place. Sometimes it moves forward slowly but having much accelerated and with very noisy engine but doesnt getting speed more than 30 mph while I am pushing accelerator upto limits. For reverse speed its working properly.
Pls. Help me to diagnose and to solve the problem. Thnx.
Sunday, November 29th, 2009 AT 4:50 PM
CARADIODOC
  • 33,916 POSTS
Transmission needs to be replaced or rebuilt. As normal wear takes place over many thousands of miles, the computer updates shift points to produce solid, crisp shifts similar to when it was new. Eventually it can't update enough to overcome the internal wear and slippage occurs.
Your mechanic can connect a scanner, (hand-held computer) to the car and read out the "clutch volume index" (CVI). This is a set of four numbers indicating how many ccs of fluid are required to apply each clutch pack. From experience, they can tell you exactly what is wrong internally, and whether repair is possible or if replacement is a more economical alternative.
Caradiodoc
Sunday, November 29th, 2009 AT 5:59 PM
EUROAIT
But unfortunately I couldn't find any mechanic near to me specialist for american cars, now I am in search for somebody having diagnostics software for chrysler dodge caravan 1996, may be it will be helpfull sortingout any problem prior than opening the transmission.
Monday, November 30th, 2009 AT 3:10 PM
EUROAIT
Thanks to cardiodoc for a prompt reply :)
Monday, November 30th, 2009 AT 3:11 PM
