1996 Dodge Caravan Stuck in First Gear
277,111 MILES • V8 • 2WD • AUTOMATIC
CAR_DUMMY
Hi Pros,
My van is stuck in first gear.
On my dashboard, the tachometer is working but the speedometer isn't. The odometer isn't incrementing either. Also, all of the 'PRND3L' indicators are hilighted so I can't tell visually what gear I'm in.
Any insight on how to correct this problem would be greatly appreciated.
Cheers!
Sep 21, 2008 at 7:50 AM
BMRFIXIT
  • 19,053 POSTS
Most likely you have lost power to the TCM
check fuses ,and wiring
check TCM for codes another common issue is
tranny solenoid pack
Sep 21, 2008 at 10:54 PM
CAR_DUMMY
Thanks MBRFIXIT!!! I'll look into it.
Cheers.
Sep 25, 2008 at 5:11 AM
