1996 Dodge Caravan Smoke
REYCRAIG
Engine Performance problem
1996 Dodge Caravan 6 cyl Two Wheel Drive Automatic
Hello
I just replaced my engine. There is a white smoke coming out of the tail pipe and it smells like gas. I put a tissue into the smoke and it got wet with what appears to be fuel. I also have a engine code 0204, "Injector Circuit #4" Does this code have anything to do with the smoking fuel problem?
Thanks
Apr 17, 2009 at 6:53 AM
  • 110,248 POSTS
White smoke is usually an indicator of coolant getting into the combustion chamber. I would check compression to make sure you don't have a bad head gasket. Also, look at the coolant level to see if it droping.
Let me know what you find.
Apr 29, 2009 at 3:01 PM
