1996 Dodge Caravan slipping
153,000 MILES • 6 CYL • 2WD • AUTOMATIC
NYCREST
I have a 96 Dodge Grand Caravan with 153k miles. The transmission slips when i am in drive. If i put the car in 3rd gear it does not slip at all and drives smoothly. All of The fluids are fine.When i am in drive and i accelerate, at first it will do nothing then the engine revs and the transmission will engage. I will also have loss of power to the transmission at cruising speed. I put the car in cruise control and it did the same. I use this car only to go back and forth from work and rarely will ever exceed 45 mph.
Aug 25, 2010 at 6:29 AM
  • 110,251 POSTS
Is the trans fluid clean and full?
Aug 26, 2010 at 3:17 AM
NYCREST
Thank you for your reply. Fluids are full and clean.
Aug 26, 2010 at 3:20 AM
  • 110,251 POSTS
Have any warning lights come on? It sounds like a problem with the torque converter, but I can't be sure.
Let me know if the light came on.
Aug 26, 2010 at 1:49 PM
NYCREST
Hi Joe, thanks for the reply. There are no lights or codes associated with this. Incredibly it drives and shifts smoothly, yet only in 3rd gear. I find your site very informative. Thanks again.
Allen
Aug 27, 2010 at 2:46 AM
  • 110,251 POSTS
I feel it either deals with the torque converter or the trans control module (TCM). However, I can't be 100% sure without a code.
Aug 27, 2010 at 5:49 PM
