1996 Dodge Caravan shifting problem
STEPHANELOYER
Transmission problem
1996 Dodge Caravan 6 cyl Front Wheel Drive 275000 miles
I have a 1996 dodge caravan sport it will not shift in third gear ( transmition has been rebuilt speed sensors have been changed) the dealer sais its electrical.
What is the broblem and how can i fix it.
Steph .
thanks
Jan 7, 2008 at 6:53 AM
DENNISM
What I would try that has worked for me on a Dodge Caravan that started doing this around 160k miles and has done it every 20-30k miles since is to purchase some throttle body cleaner in a spray can. Remove the air intake at the throttle body (hose clamp needs to be loosened to remove. Hold open the butterfly that the throttle cable is attached to by rotating with your hand and spray until the residue running out is no longer brown. This fixes my shfting into high problem. The other thing it fixes is stalling at traffic light idle that happens around the same time.
Jan 9, 2008 at 11:54 AM
