1996 Dodge Caravan scan tool
GOFFERS1
  • 21 POSTS
Engine Mechanical problem
1996 Dodge Caravan Automatic 87,000 miles
could you recommend a basic inexpensive scan tool for map sensor voltage and one that can be used in voltmeter mode.
Thanks!
Jun 16, 2010 at 1:35 PM
BMRFIXIT
  • 19,053 POSTS
For in home use ,cheap small OBDII reader should do just fine and no need for the big and expensive scanner
Jun 16, 2010 at 1:38 PM
GOFFERS1
  • 21 POSTS
[quote:83a97e6367="BMRFIXIT"]For in home use ,cheap small OBDII reader should do just fine and no need for the big and expensive scanner[/quote:83a97e6367]
Thank you very much!
Jun 16, 2010 at 1:44 PM
