I thought I'd save a few bucks and replace the entire strut ass'y for both front wheels myself. Done this multiple times for 1995 Dodge Caravan but the configuration was a bit different.
I ran into a problem on the driver's side when trying to detach the sway bar from the strut. I stripped the torx head. I've never tried to loosen a torx head before but my son was holding a wrench on the nut part so it wouldn't turn, and I proceeded to turn "left". It turned a bit then became difficult. So I turned "right". Same thing, until it stripped.
Can this be drilled out, and if so, is it something I could do? Also, I really want to see this project through myself but as you can tell I'm not a mechanic - just someone whose learning as he goes. What advise do you have for me on the passenger's side?
Thanks for your help.
Jason
Jason
Apr 20, 2008 at 6:27 AM
