HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Drivetrain
Transmission
Symptoms
Not Shifting
SPONSORED LINKS
1996 Dodge Caravan not shifting into 3rd gear
GERT8474
MEMBER
1996 DODGE CARAVAN
6 CYL
2WD
AUTOMATIC
140,400 MILES
My transmission is not shifting into 3rd gear while driving until reaching high speeds. What causes this?
Tuesday, November 4th, 2008 AT 2:21 PM
ZACKMAN
MECHANIC
Do you have enough fluid? Do you have the right fluid (ATF +4)?
If yes to both questions, you may want to check the out speed sensor on top of the transmission.
SPONSORED LINKS
Tuesday, November 4th, 2008 AT 10:57 PM
GERT8474
MEMBER
1 POST
Yes, fluids are all good. Thanks for the info we'll give it a try.
Friday, November 7th, 2008 AT 7:38 AM
Please
login
or
register
to post a reply.
Related Transmission Not Shifting Content
1996 Dodge Caravan Shifting Problem
Transmission Problem 1996 Dodge Caravan 6 Cyl Front Wheel Drive 275000 Miles I Have A 1996 Dodge Caravan Sport It Will Not Shift In...
Asked by
stephaneloyer
1 ANSWER
1996
DODGE CARAVAN
1996 Dodge Caravan Transmission
I Was Driving Home The Other Night In My "96 Grand Caravan Le When I Noticed The Lights Were Fading Out. I Limped It Home (about 35 Miles)....
Asked by
worldfamouspj
1 ANSWER
1996
DODGE CARAVAN
Will Not Shift Into Overdrive
Will Not Shift Into Overdrive And Runs High Rpms At 45-mph
Asked by
FrankieW31
1 ANSWER
1996
DODGE CARAVAN
Transmission Will Not Shift Out Of Low Gear
Transmission Will Not Shift Out Of Low Gear When Its At Running Temp. After It Is Shut Off For 10-15 Minutes And Re-started It Shifts Okay
Asked by
martincarter
5 IMAGES
1996
DODGE CARAVAN
Transmission Not Shifting Properly And Code P0888
I Have Problem With Automatic Transmission It Is Not Shifting. And I Have The Fault Code P0888.
Asked by
faisal.nagem
5 IMAGES
2004
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Transmission Turbine Sensor Replacement
Transmission Speed Sensor Replacement Honda
Transmission Mount Replacement - RWD Cars
Online car repair manuals
