[quote:06678ede2a="Travis Ingram"]Engine problem
1996 Dodge Caravan 6 cyl Front Wheel Drive Automatic 14600 miles
How do you loosen the tension pulley to loosen belt.[/quote:06678ede2a]
If it is a 3.3 or 3.8 you will find a screw head on the pully. You will turn it away from the belt. It is spring loaded btw.
Dec 22, 2007 at 2:44 AM
