1996 Dodge Caravan no start
LARGE
Electrical problem
1996 Dodge Caravan 6 cyl Two Wheel Drive Automatic
I have been having problems with my van it stopped running one day and never started again i get engine rotation but no fire to the plugs, i have replaced the coil pack, cam and crank sensor. No luck, my fuel pump is running filters are good timing belt is fine, fuses are good relays are good dont know where to go next, was thinking of the engine control module but not sure how to test it. any help would be much appreciated thanks in advance.
May 16, 2009 at 11:19 AM
BMRFIXIT
  • 19,053 POSTS
Check fuses and relays
mark ASD relay and switch with another
check for power at the coil when 1st key on
key on do you have check engine light on
you should
crank engine does the light go out
let me know
also cycle key on off on off on
read what you have for codes in odometer area
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 16, 2009 at 11:24 PM
