1996 Dodge Caravan no spark
FERREIRASBACK
Electrical problem
1996 Dodge Caravan 6 cyl Automatic
Hi i have a caravan that has no spark i changed the ignition switch today and it still will not start.. Do you have any ideas what it might be please help...
Apr 19, 2010 at 7:44 AM
BMRFIXIT
  • 19,053 POSTS
Suspect crank sensor
What V 6 engine you have?
Key on engine off do you have check engine light on? you should
Crank engine does the light go out
If not suspect crank sensor
Check for codes and ASD relay
Apr 22, 2010 at 1:35 PM
