1996 Dodge Caravan No Fuel From fuel pump
R ALLEN
1996 Dodge Caravan 6 cyl Two Wheel Drive Automatic
Van will not Start with new fuel pump has no fuel in line -New fuel filter- relay is good - fuse is OK - Has Spark -fuel in tank -no noise in tank from fuel pump--- Could it be the camshaft position Sensor
Aug 29, 2009 at 5:34 PM
  • 75,988 POSTS
Do you hear the fuel pump come on when you turn key to run? If so check the fuel pressure to rule out the fuel pump if not check the fuel pump fuse and fuel pump relay
Aug 29, 2009 at 6:55 PM
