1996 Dodge Caravan no fire to the coil
120,987 MILES • 6 CYL • FWD • AUTOMATIC
JAMES KEITH
I was driving and my van suddenly stopped running and it's not getting fire to the coil.How can i fix the problem?
Jun 14, 2010 at 3:09 AM
INTERNETMECHANIC
  • 700 POSTS
Check for applicable mil codes. I'm not sure of engine litre size. I looked at 3.0. If there is no spark at plugs, did you check primary voltage at the coil? Engine cranking, dark green wire with orange tracer should be hot. That voltage comes from the asd relay,but, if the computer doesn't see the cam and crank signal, it may not ground the asd relay. I'd want to check for the cam and crank signals before suspecting the relay.
Jun 14, 2010 at 4:14 AM
