1996 Dodge Caravan no fire or fuel to the cylinders
PTWHITT
Engine Mechanical problem
1996 Dodge Caravan 6 cyl Front Wheel Drive Automatic
Replaced timing set, new crank and cam sensor, fuel pump pre primes but no fuel to cylinders and no fire to the engine
Oct 28, 2009 at 2:38 AM
  • 75,988 POSTS
No fuel and spark that's if this is what you're saying okay-lets check the fuel pressure with gauge if its within specs and also check for injection pulses. If both okay test the ignition system disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark?
Oct 28, 2009 at 3:00 AM
PTWHITT
We have done all what you said but no blue spark.
Oct 28, 2009 at 3:05 AM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Oct 28, 2009 at 3:23 AM
