1996 Dodge Caravan Newly Replaced Fuel Pump/Filter
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
REYCRAIG
Hello, I just changed my fuel pump & filter and the van was not getting fuel. I checked and discovered that the pump was not getting power. I jumped the pump and I heard the pump operating. During the jump, I disconneted the main filter output to see if gas will come out and it was just air, not gas. Any advise will be appreciated. God Bless!!
Jul 28, 2008 at 4:41 AM
  • 75,988 POSTS
Test the auto shut down relay and fuel pump relay to include the PTC 1 9amp.
Jul 28, 2008 at 5:20 AM
REYCRAIG
Hello, Thanks for the lightning quick answer. Where exactly is the PTC 1 9amp? I have located the other relays. I am still confused why when direct power is applied to the fuel pump, gas would not pump out. There are quite a few fuel lines. Could there be an configuration problem?
Jul 28, 2008 at 11:16 AM
  • 75,988 POSTS
PTC 1 9amp is in the junction block-see below Verify the fuel hose fuel return and pressure feed side if okay check the fuel pump you might hear it coming on but not producing pressure-check it
https://images.2carpros.com/forum/automotive_pictures/12900_ptc_1.jpg
Jul 28, 2008 at 1:28 PM
