1996 Dodge Caravan New Fuil pump not pumping fuel
1996 DODGE CARAVAN
R ALLEN
Interior problem
1996 Dodge Caravan 6 cyl Two Wheel Drive Automatic
Van will not Start with new fuel pump has no fuel in line -New fuel filter- relay is good - fuse is OK - Has Spark - fuel in tank - no noise in tank from fuel pump--- Could it be the camshaft position Sensor
Aug 29, 2009 at 7:18 PM
I gave you something to work with -stay in your original post and do what I've suggested and comeback with some results before I can continue to help you-The sensors got nothing to do with no fuel in line-Maybe for spark and injector synchronization
Aug 29, 2009 at 7:25 PM
What's your problem why did you gave me a negative feedback-you want help or what I can remove your feedback anytime I'm a moderator in here-My job is to help people in need.
Aug 29, 2009 at 7:40 PM
