1996 Dodge Caravan Left Turn Signal Not working
200,000 MILES • 6 CYL • FWD • AUTOMATIC
BCOMDOHR
I replaced a left tail light assembly and now the left turn signal and flasher do not work. The front left turn signal blinks very fast. I replaced the bulb, but that did not help. I am not sure if the turn signal worked before because the light has been broken for a long time.
Jan 10, 2009 at 4:44 AM
BMRFIXIT
  • 19,053 POSTS
Make sure you used the correct bulb in the right place (rear )
and if so check ground wire
(rear)
Jan 10, 2009 at 6:07 AM
BCOMDOHR
I have the correct bulb so how do I check the ground??
[quote:da8343ab20="BMRFIXIT"]Make sure you used the correct bulb in the right place (rear )
(rear)[/quote:da8343ab20]
Jan 10, 2009 at 7:25 AM
BMRFIXIT
  • 19,053 POSTS
use a test light connected to a known good power and or use voltmeter
at the bulb socket u should have power and ground
if not check the wire of what missing
Jan 10, 2009 at 10:50 PM
