1996 Dodge Caravan knocking
216,000 MILES • 6 CYL • 2WD • AUTOMATIC
DANIEL1OB
when i turn the wheels without moving forward or back there is a loud crunching from the front axle and when i start moving there is a knocking at the front as well. what could this be?
Aug 2, 2010 at 5:51 AM
  • 110,248 POSTS
Does it sound like dried out rubber bushings when you turn the wheel? Also, the clunking, does it change with vehicle speed, turning, bumps...?
Aug 2, 2010 at 5:10 PM
DANIEL1OB
not sure about 'dried out rubber' but it definetly sounds as if something needs oiled.... the guy i bought the car off showed me receipts of the work that he had done on the front of the car!! and yes, when i get to about 40mph the knocking somewhat stops. when i turn the wheels it sounds to me like its metal crunching (only when i dry steer). and i do know that the alinement is off slightly.... could that be the knocking??
Aug 3, 2010 at 1:36 AM
  • 110,248 POSTS
I would start by checking the sway bar bushings. As far as the alignment, it wouldn't cause it.
Aug 3, 2010 at 4:31 PM
