I have a 1996 Grand Caravan with the 3-speed transmission and a 3.0L engine. Recently the speedometer has been jumping around causing the cruise control to fail,the vehicle may stall at slow speeds and and lurches or "boggs down" in the process. I replaced a coolant temp sensor, purge solenoid, O2 sensor, speed sensor and wiring harness at both a mechanics shop and transmission shop to no avail. Tonight the fuel gauge also failed to work until I arrived home and shut off the van then restarted. My best guess is an engine control module.
May 6, 2009 at 3:06 PM
