1996 Dodge Caravan ignition
1996 DODGE CARAVAN
180,780 MILES • 6 CYL • FWD • AUTOMATIC
YVETTE COOK
Key has been hard to turn, now stuck in ignition.
Oct 1, 2009 at 5:54 PM
JEEPFAN
  • 135 POSTS
try getting some dry graphite lubricant the spray type and spray it all around the the switch and around where the key is in the switch and work it moving it as much as it will back and forth if you get the key out put the lubricant in the slot and insert and remove the key several times
Oct 1, 2009 at 6:19 PM
