1996 Dodge Caravan flickering lights in dashboard go on and
SOKOLAN
Electrical problem
1996 Dodge Caravan V8 All Wheel Drive Automatic
we have lights that flicker on and off at odd times
what can the promblem be and its in the dashboard
Apr 14, 2008 at 3:36 PM
LEGITIMATE007
  • 5,121 POSTS
sounds like your dimmer switch may be getting ready to quit on you, have it tested to see if its still good or maybe you can go to the junk yard and pull one off of another van, should be inexpensive, does it seem to do it when you go over bumps?
Apr 15, 2008 at 12:24 AM
SOKOLAN
Head light switch and dimmer switch were changed, didn't solve the problem.
Apr 15, 2008 at 4:21 AM
LEGITIMATE007
  • 5,121 POSTS
then you body control module will have to be checkes to see if any loose wires. Also pull the speedometer out and make sure the bulbs arent loose
Apr 16, 2008 at 3:58 AM
