1996 Dodge Caravan engine starting problem
181,000 MILES • 6 CYL • FWD • AUTOMATIC
JIM4215
My door key doesn't always shut off the alarm system when entering and the alarm sounded when I started the engine. I had to use the door key to stop the alarm and now the engine starts but shuts down immediately. Also the digital odometer and transmission indicator don't illuminate when turning on the ignition as before. I've tried swapping the engine computer with a good one from an identical van I own. Could there be a body control computer problem or an anti-theft lock-out in the system ?
Oct 28, 2009 at 4:36 PM
  • 110,248 POSTS
Chances are there is a problem with the security system. Is it a factory system?
Nov 2, 2009 at 2:53 AM
