1996 Dodge Caravan engine light
91,000 MILES • 6 CYL • FWD • AUTOMATIC
GOFFERS1
  • 21 POSTS
Can one problem trigger a series of codes? I just had a repair job done and the engine light is on again. Codes are 24, 32, 43 and 61. I just had throttle position sensor replaced and an 02 sensor. The car runs fine, but can't figure out why these codes are coming up.
Sep 6, 2010 at 9:49 AM
  • 110,248 POSTS
24 is the tps. The 32 Logic module did not see a change in air/fuel ratio when EGR circuit was activated which could be caused by the tps. The 43 Ignition coil driver circuit open or shorted. That has nothing to do with the TPS.
Sep 6, 2010 at 2:01 PM
