1996 Dodge Caravan ecm
1996 DODGE CARAVAN
130,000 MILES • 6 CYL • FWD • AUTOMATIC
ANTWAIN
when i hooked it up to the computer it said probable couse ecm defective or service reminder modules faild internally or informations between modules needs updateing what would u say is the problem or where would u start and finally where is the computer located on the van in case i must replace it
Apr 6, 2010 at 3:02 AM
CH112063
  • 1,320 POSTS
On a Dodge, the computer that controls the engine is called a powertrain control module(PCM). Check all the fuses in the power center next to the battery, and thats where you'll find the PCM, on a 96, it was mounted on the left inner fender behind the battery. ok Your getting a code for an internal failure. I would have it scanned again, and be sure it's the PCM and not the transmission module(TCM) that has failed, after you test the fuses, ok.
Apr 6, 2010 at 1:54 PM
