1996 Dodge Caravan do it myself caliper installation
190,000 MILES • 6 CYL • FWD • AUTOMATIC
LAMON 17
to all who is familiar with installing brake calipers on a 96 dodge caravan , I'm asking for step by step instructions on how to install them. Please use the simplest terms as possible because I am not friends with to many car terms. Thanks for your valuable time. If If could, I would pay you a million dollars of IOU,s
Oct 25, 2008 at 10:01 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Check out the link below.... It will show you how to remove the caliper to replace the brake pads and rotor. The procedure is the same to replace the caliper except that you will need to remove the brake hose connected to the back of the caliper.
https://www.2carpros.com/articles/brake-caliper-replacement
Feb 25, 2021 at 12:27 AM
