1996 Dodge Caravan Do I need an alignment?
FRAD_4
Shakes or Wobbles problem
1996 Dodge Caravan 6 cyl Two Wheel Drive Automatic 161k miles
While driving the car seems to shake. It also tends to veer left when no holding the steering wheel. Do I need an alignment. Also I haven't been able to afford changing all my tires at once so I recently purchased a new tire on the rear left side.
May 3, 2009 at 7:10 AM
  • 110,248 POSTS
It sounds like you could use an alignment. Also, just make sure to purchase the same size tires if you replace them one at a time.
May 12, 2009 at 3:44 PM
