1996 Dodge Caravan codes?
LARRYTRAYER
  • 5 POSTS
Can you please tell me what codes 32 and 42 mean?
Thanks
Jun 8, 2007 at 4:18 PM
E40WATER12
  • 522 POSTS
I think code 23: Is Incoming air temperature sensor may be bad.
code 42 : Automatic shutdown relay circuit open or shorted.
Jun 8, 2007 at 8:44 PM
GLENFRANC
what is code 55 ?
Jun 26, 2007 at 7:13 AM
ROGERDOGER
There are relays under the hood. Look at the diagram on the relay cover. Try changing some of them around to see if a relay or two is bad.
Aug 16, 2007 at 4:38 PM
L_BOURGON
32 EGR gases not working
42 Automatic shutdown relay circuit open or shorted
42 Fuel pump relay control circuit
42 Fuel level unit - no change over miles
OR
42 Z1 voltage missing when autoshutdown circuit energized
55 End of codes
Aug 25, 2007 at 12:42 AM
