1996 Dodge Caravan Code P0106
1996 DODGE CARAVAN
10,300 MILES • 4 CYL • 2WD • AUTOMATIC
BUBBLY12
I recently had the catalytic converter replaced with a magnaflow direct fit cat converter . After driving a few miles I got :service engine soon" and in checking with my scaner got a P0106 code which in my shop service manual indicates "MAP sensorhas a bao reading below an accepatable level" . Never having got this code before I am assuming that the problem is the result of changing the converter. Assuming that the MAP sensor is not at fault problem what should I look for as being the problem?
Aug 28, 2010 at 7:04 AM
BLUELIGHTNIN6
  • 16,542 POSTS
bad wiring, PCM or MAP sensor are causes for this code to appear
Aug 28, 2010 at 7:08 AM
