1996 Dodge Caravan Changed my trans fluid and filter
1996 DODGE CARAVAN
198,000 MILES • 6 CYL • FWD • AUTOMATIC
CAMERONPHA1123
tranny gasket was leaking
Changed trans fluid, filter and gasket. Now my tranny acts like it is drunk, when I come to a stop, and try to accelarate again, it will try to about a second or two before downshifting into 1st again, then all is fine until the next stop sign or light. problem gets less noticable about 15-20 minutes into the trip.
i used "high milage" tranny fluid from auto zone, and the only gasket and filter kit they had. i was considering adding lucas transmission fix, thier engine stuff works great, fixed the blow by i had.
Sep 23, 2009 at 1:23 PM
BMRFIXIT
  • 19,053 POSTS
tranny fluid should be ATF + 3 if used DEX OR F fluid
it not going to work well in your tranny
make sure that the fluid level it up to mark with engine running
Sep 26, 2009 at 11:52 PM
