1996 Dodge Caravan Car won't start
225,000 MILES • 6 CYL • FWD • AUTOMATIC
DRIVERPILOT02
Motor size is 3.0-My car will turn over fine but won't fire. I found a crack in the distributor cap and replaced it. I also replaced the ignition coil because fire wasn't getting to the distributor from there. Don't really know where to go from there. Hoping for some help. Thanks.
Feb 28, 2008 at 6:59 AM
BMRFIXIT
  • 19,053 POSTS
you still have no spark after replacing the cap
check / replace the crank sensor
if you have spark at the wires by the plugs
then check fuel pressure and fuel pump
let me know
Feb 28, 2008 at 11:05 AM
