1996 Dodge Caravan camshaft position sensor for a 1996 dodg
ASHER78
1996 Dodge Caravan Automatic
Could you tell me the procedure for removing and reinstalling a camshaft position sensor for a 1996 dodge caravan 3.0 and where to find the camshaft position sensor to begin with?
Apr 20, 2010 at 12:24 PM
CARADIODOC
  • 34,399 POSTS
Hi asher78. Welcome to the forum. The camshaft position sensor lives inside the distributor. I've never had to replace one and I can't find any reference to replacing it in the service manual either. If you're sure it's bad, start by looking at the new sensor to see what it looks like. If I could find an exploded view, I could tell you if the distributor's shaft has to come out.
The sensor should be under a sheet metal cover after the rotor is unbolted. Holler back if you can't figure it out by looking at the new one.
caradiodoc
Apr 20, 2010 at 1:06 PM
