1996 Dodge Caravan automatic window switch
10,600 MILES • 6 CYL • FWD • AUTOMATIC
MORNINGMOM
Passenger automatic window switch will not work on the passengers side. It will work on the drivers side. Is this something I can repair myself by removing the door panel? Or, do I take it to a mechanic?
Mar 31, 2009 at 1:47 PM
EUGENE123
  • 273 POSTS
first start by checking all your fuses if they are all ok then to change the motor the door panel has to come off, this job is not a really big job and may could be done by yourself, but if you don't know anything about removing door panels or about replacing the motor you may think about a mechanic
Mar 31, 2009 at 3:38 PM
