1996 Dodge Caravan 240,000 miles, 3.3L
RJSCHMIT
I have a 96 Dodge Caravan that I just had the tranny replaced on. After I got it back, there were some error codes showing up - #6 injector and #6 cylinder - #27 and #43.
There are some frayed wired going into the #1 & #6 injector connectors, but most of them look pretty bad/worn.
I'm thinking of replacing the entire injector harness, but am also thiinking it may be the injector itself.
How hard is it to replace an injector and do I need any special tools?
Please give me some insight into how to proceed...
Thank you very much
Nov 26, 2007 at 3:17 PM
BLACKOP555
  • 10,386 POSTS
to replace the injector is pretty easy, just involves taking off the intake manifold. once that is off to remove the injectors it takes a firm pull they should come right out, besure to put on new o-rings when replaced lube them up with light grease, DONT USE SILICON. No special tools required.
i would replace the harness first, then if that doesnt clean things up check the injectors, could save you some time.
Nov 26, 2007 at 11:12 PM
