1996 Dodge Caravan
1996 DODGE CARAVAN
135,000 MILES • 6 CYL • FWD • AUTOMATIC
SORT14
how do i reset the computer? my fluid was low and my oil pressure gauge came on and shut my engine down. i refilled the oil and still no start. i need to reset the computer to clear the automatic shutdown.
May 8, 2009 at 4:13 PM
BMRFIXIT
  • 19,053 POSTS
Check for codes before resetting the PCM
if you ran out of oil I would be more concern about the engine and not the ASD relay
does the engine crank ?
and if so check for spark and check for fuel and fuel pressure
disconnecting the battery will reset all codes
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 8, 2009 at 11:19 PM
