1996 Dodge Caravan
ALL4CHAMBERS
Tires and Wheels problem
1996 Dodge Caravan 6 cyl Front Wheel Drive Automatic
how do i get the power stering pully on bought new one pully and pump and they onlt give you one long bolt but the pully only goes on shaft half way
Jan 24, 2009 at 10:45 AM
WAHASKELL2
  • 7 POSTS
hello,first of all did you make sure that the pulley is on the right way? its easy to put it on inside out.and are you using the washer? some auto parts stores will loan the tool incase it is on inside out then you can get it right off quick and easy. good luck,i hope this helps
Jan 25, 2009 at 11:52 AM
