1996 Dodge Caravan
JRASMUSSEN77
Steering problem
1996 Dodge Caravan 6 cyl Front Wheel Drive Automatic
power steering is out but res. is full
Jan 3, 2010 at 8:56 AM
CH112063
  • 1,320 POSTS
Hello, does it make any noise at all? and I am sure the belt is tight? Couple of things could be wrong, all hydraulics run through this pump and it needs to build and hold a certain amount of pressure, it, like most oil pumps use a check valve, internal to the pump. The noise and feel tells you plenty.
Jan 3, 2010 at 11:20 AM
